Hi chaps,went to this m/c a couple of weeks ago,and the little yellow door interlock pin ? had come thru into where you grab the front of the door.
if you slid the pin back the door opened easily.so i stripped down the door and refitted the pin.after a couplr of weeks the customer has the same fault.what does this pin (bout the length orf a cocktail stick)do ?
should i fit a new interlock?
Many thanks 🙁
