Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch sgs46e22gb/01
- This topic has 6 replies, 2 voices, and was last updated 8 years, 3 months ago by
mikehha.
December 22, 2017 at 6:23 pm #92901
mikehha
ParticipantHere’s one to ponder over during the Christmas break.Went to this dishwasher because it was filling and emptying at the same time so assumed it was the impeller jug so fitted a new one but no it was the same.So it must be the control card 644781 fitted this now the dishwasher runs but the water level is high and when the cycle pump stops it starts to pump out a little bit What I would like to know is, Is it possible to alter the water level or what could be causing this to overfill ,or could it be that the cycle pump is not pumping hard enough.well what do you think.
December 22, 2017 at 7:28 pm #452519Martin
ParticipantRe: Bosch sgs46e22gb/01
The float chamber under the fill matrix needs stripping and cleaning, including the tub transfer pipe.
December 22, 2017 at 9:38 pm #452520mikehha
Sorry Martin not this time . This is the cleanest dishwasher I have seen it’s 10 years old and there is not even any muck in the air break. (Matrix)
December 22, 2017 at 10:28 pm #452521Martin
Hmm? Yes, might have to ponder this a while. The impeller jug and control unit work together to establish the water level based on time (i.e litres per min) so it is pre-set and cannot be adjusted. I doubt you have fitted the jug the wrong way round but worth asking all the same. Also the connection between could be suspect?
December 23, 2017 at 7:36 pm #452522mikehha
You know I doubt it myself so took out the jug again just to check.but I didn’t check the cables but surely not?.
December 23, 2017 at 9:35 pm #452523Martin
I seem to recall I had one once, long long ago, where the jug was faulty but it overfilled on test afterwards. I reset it after a couple of fill cycles then it was OK after that.
Try it, it might like it? Happy Christmas!!
December 24, 2017 at 9:53 am #452524mikehha
Thanks Martin .have told the customer to go on and use it.might fit another jug in the new year.
All of you Have a very happy Christmas.
Mike -
