Bosch SGS46E22GB/90 dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS46E22GB/90 dishwasher
  • #58792
    SMO
    I am having some problems with the above. I normally set the timer and run the machine overnight, but last week I came down in the morning and noticed that all of the lights were off, indicating that it had popped the fuse. I have a fuse above the work top and the plug is below the worktop, so I changed the fuse above the worktop. The machine sprang into life again – it had gone off with about 28 mins left on the cycle. It finished the wash. I had one wash with no problems, then the second one did it again. Again I changed the fuse, it had 128 mins left on the program. It popped again and has once more since. All at different times in the cycle. When I exchanged the fuses with the washine machine to check if they had blown – they had not – only the dishwasher goes off. The fuse box is ok too. I didn’t pay a huge amount for the machine and I would rather repair it – but not if it will be unreliable and I end up replacing it in 3 months anyway.. The machine is about 18months – 2 years old. Can anyone give me any advice on this?
    Many thanks.
    #335703
    Jonah
    Re: Bosch SGS46E22GB/90 dishwasher
    If it’s under 2 years old it will still be under warranty from Bosch if you registered the warranty, other than that the obvious fault would be the heater faulty but you will need to check all components with a meter to diagnose correctly, remember plug out before you start :zap:
