Hello,
I have a Bosch SGS47E02GB/56 dishwasher. We suffered a flood in the kitchen. Once the dishwasher dried out it was fine except for the circulation motor which suffered some bearing damage. When I ran it the washer it all worked (except for the noisy motor).
I have now replaced the motor and it all works okay except the water is not being heated.
I have checked the heater element and it’s reading around 25-30ohms. I’ve also checked the control module and the pcb, components and soldered joints all look okay.
When the washer is running there is no voltage reading across the heater, either directly or before the pressure switch (eliminating the heater element and pressure switch as the source).
What else can I check ? Is there a separate temperature sensor somewhere ?
Keith
(I am a qualified electrical engineer, so I know all about electrical safety)
