Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › bosch SGS47EO2GB/35 full of water
- This topic has 7 replies, 3 voices, and was last updated 16 years, 2 months ago by
slyp98.
January 21, 2010 at 10:44 pm #51863
slyp98
Participanthi guys ,ive seen a few similar problems here i just need to clarify if i have the same problem , d/w is full of water ,the matrix is half full of water the part of the matrix that comes to the bottom of the d/w has a solenoid where it turns into the flexi hose that goes to the drain , when i turn on the d/w lights come on and i can hear the pump trying to run , i say trying because its a faint hum it does this for 15 – 20 seconds and stops and comes on again faint hum 15-20 sec stops about 3 or 4 times does this indicate a blockage in the pump? and where exactly is it acessable from outside or inside the cavity ? thanks fellers
January 22, 2010 at 12:23 am #309608Penguin45
ParticipantRe: bosch SGS47EO2GB/35 full of water
Two pumps. Drain and circulation. When you start a programme it should drain. Press the two buttons with the dots and the line underneath and it should cancel the programme and drain out. If it does, the drain pump is fine.
Your description points more towards a circulation pump problem. It may be jammed, blocked or seized due to leakage. If it is free to turn, the start/run capacitor may have failed.
Power off for anything other than observation.
January 22, 2010 at 10:00 am #309609slyp98
hey penguin , its not draining when i do a reset it just starts the humming process in the pump as above so im guessing drain pump ? oh and i cant get any diagrams from the bshappliance care site it keeps telling me to ring the helpline any other links to a diagram of this m/c thanks
January 22, 2010 at 5:54 pm #309610nomadPaul
ParticipantDefinitely sounds like a blocked drain pump. When working normally , they will work/stop/work/stop/work/stop…then pump continuously. If you look in the very bottom of the sump inside , is there a white cover with a single torx 20 headed screw holding it on ? If there is you moght want to try taking this cover off as this will expose the pump impellor and you may find a piece of glass/crockery or bone trapping the impellor.
Remember to fix the cover back on before testing though as it won’t drain without it .January 22, 2010 at 6:48 pm #309611slyp98
cheers p will have a look 2moro , is there a related solenoid or capacitor that could fail causing a similar problem ?
January 22, 2010 at 8:11 pm #309612nomadPaul
ParticipantNot really. If you put it on reset and it doesn’t drain – and you can hear a faint buzz , then it’ll be either a blcoked or knackered drain pump. When you reset the appliance , the drain pump is the only working part that is activated.
January 22, 2010 at 10:26 pm #309613slyp98
good stuff thanks a mill 😀
January 23, 2010 at 12:25 pm #309614slyp98
ok guys , took apart the cover in the sump , the pump was a bit sticky and there was a trace of food on the inside of the cover plate so i washed it off spun the impeller around a few times replaced the cover and it started up straight away drained water and stopped . i ran a 45 degree quick wash and all is well , thanks for all the advice penguin and nomad 😀
