Bosch SGS47EO2GB – not draining water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS47EO2GB – not draining water
  • #42052
    purplehot-pants
    Anyone got any ides why my Bosch is not draining water away? Have cheked the filters and the pump and nothing blocking them. Typical three days before Christmas and a house full of people!
    Emma
    #272237
    nomadPaul
    first things first – can you hear the pump running if you re-set the appliance ?
    If not , re-check the drain pump carefully.
    If it’s running but still not draining , check the drain connection….especially if its connected to your waste under a sink .
    #272238
    richardable
    Re: Bosch SGS47EO2GB – not draining water
    it may be the drain matrix at the back of the w/m…i am not familiar with the model but….if you can pull the machine out…power off of course, and the drain hose is at the top right hand corner, take the lid off and check the plastic matrix which is tubed to the drain pump and the drain hose is directly connected to it on the outside of the machine…even a small bit of fabric lint can stop the drain process.
    hope this helps
    richard
    #272239
    richardable wrote:it may be the drain matrix at the back of the w/m…i am not familiar with the model but….if you can pull the machine out…power off of course, and the drain hose is at the top right hand corner, take the lid off and check the plastic matrix which is tubed to the drain pump and the drain hose is directly connected to it on the outside of the machine…even a small bit of fabric lint can stop the drain process.
    hope this helps
    richard
    “Cough”, its a dishwasher Richard, 😉 🙂
    richardable
    thanks jim
    having a CRAFT moment
    richard
    :rolls: :rolls: :rolls:
    #272241
    purplehot-pants
    Thanks for all these tips. The pump is working, it is draining away some of the water but not all, the drainage hose is not blocked so we are still at a loss as to what the problem is! The dishes are coming out clean though, so if anyone has any other thoughts they would be much appreciated.
    Merry Christmas
    Emma
    #272242
    Richards’ senior moment is not entirely without merit. The machine has a matrix under the left hand side panel. The rear two tubes are the drain section. It is possible for an obstrudction to build up in there. Also worth looking at the top left corner for fat deposits. Thorough cleaning and violent shaking will dislodge most of it. Failing that, the drain hose itself may contain a foreign body, ot the sink coupling itself (if applicable).
    Power off first.
    purplehot-pants
    Thanks for this – but being a novice, a silly question I know, but how do you access these tubes, pipes and matrix? 😀
    #272244
    richardable
    i have recovered from the senior moment now…the drugs have kicked in..to get to the matrix, …remove the top lid of d/w….remove left side panel and all will be revealed..look at the plastic matrix and there could be a build up of food waste which stops the d/w draining…
    8)
    richard
    happy christmas
    #272245
    purplehot-pants
    Hi everyone
    Thank you all so much for this information, it is really helpful and hopefully will lead to many clean and water buildup free washes tomorrow!!
    Merry Christmas to all
    Emma
