All right, you clever Bosch engineers, see if you can give me a pointer on this one…..
Above machine intermittently turns itself off at the I/O switch at random points in the cycle. It is a proper ker-click manual switch, with the interlock rod to the door catch. I have replaced the switch, but apparently it is still doing it. Not when I’m there, of course. The door latch is engaging most securely by the way.
FD is 7709 if required.
Cheers,
