BOSCH SGS5302GB/07 abnormal noises
Home Forums Public Support Forums Help And Support Dishwasher Help Forum BOSCH SGS5302GB/07 abnormal noises
Viewing 15 posts - 1 through 15 (of 22 total)
  • #43190
    pooroldcodger
    Hi everybody.
    I am a first timer to your forum, looking for some advice if possible.
    My SGS5302GB/07 has just started to make a noise which sounds like a motor working hard to turn something over, but not doing anything. This starts when the wash programme should be starting. I have felt with my fingers in to where the pump impeller is, and it seems to be moving as well as I can tell. Because I only had a new electronic controller fitted to this machine 12 months which cost quite a bit, I feel more inclined to have it fixed / try to fix it, than perhaps I would if it had never been repaired before. If this is an impeller and or pump fault, how feasible is it for a non white goods engineer to access the necessary parts on this machine? I can work on cars ok, but dishwashers are new ground! I can’t even figure out how to get at the impeller!
    Any advice respectfully received.
    #276324
    Re: BOSCH SG5302GB/07 abnormal noises
    Is the circulation motor making a humming noise? It is a capacitor start/run motor. If the capacitor loses it’s ability to charge, the motor gets power but will not go.
    The correct way to check that the motor is free to turn is to remove the lid and the r/h side panel and gently move the motor from that end. Power off first, of course.
    Capacitor is HERE if required.
    pooroldcodger
    Re: BOSCH SGS5302GB/07 abnormal noises
    It sounds more like a motor going round than a power hum. A bit like a car engine being cranked over but it not firing. How do you get the lif off? It doesn’t seem to want to move. Is there a knack to it?
    #276326
    Two lift up latches at the back. Force required………
    pooroldcodger
    Is it, from the back,push the 2 catches up and pull it towards you?
    #276328
    Lift latch on one side, give lid a thump to the rear, then do the other side.
    pooroldcodger
    OK, top and right side panel off now thanks!
    I can now see the back end of the motor. What’s the next suggestion?
    #276330
    pooroldcodger
    When I turn the impeller with my fingers from inside the sump, the armature is moving when viewed from the end of the motor, so at least I know the impeller is still connected to the shaft!
    #276331
    nomadPaul
    When you start a cycle , does the DW fill properly with a full water level and then start to work…or does it immediately mae this noise ?
    It could be the motor running ’empty’ if the appliance actually thinks its full of water .
    start a new cycle and listen . You should hear it pump out for about 30sec , then fill with water and then start to ‘wash’.
    Post here again if any different .
    #276332
    pooroldcodger
    Hi.
    When you push the start button it sounds normal. It pumps out, it fills, and then at the point (about 45 secs at a guess after pressing start) when it normally starts making a steady droning sort of noise when the washing starts, instead I’m getting a sound like a car trying to start. Like a wah waha wah wah noise, much harsher and higher pitched than the normal droning noise.
    #276333
    nomadPaul
    Once this noise starts , open the door and let us know how much water there is in the bottom of the tub.
    #276334
    pooroldcodger
    Will do. I have to reconnect it first. How much should there be?
    #276335
    pooroldcodger
    When the noise started I opened the door. The water level was barely to the top of the sump. In fact until I took the filter out I couldn’t actually see any water at all. I tipped a couple of jugs of water in (about 6 pints worth) shut the door and pressed start and the noise definitely changed. Does this give us any clues.
    #276336
    Right. Remove the l/h side panel, you’ll find this:
    The water level should be halfway up the salt cap, if the unit in the picture and the hose coming out bottom right ard full of congealed goo, it will underfill badly, then strange things happen……….
    Strip and clean; try again.
    Power off first.
    pooroldcodger
    The vessel filled with goo in your picture looks ok on mine, but, in the matrix where the water inlet comes in , there is a lot of goo at the top of the pipe. Looks like it needs cleaning out. Have you any tips on how to get it off?
