I’ve checked the drain and the impeller under the cover. The impeller turns but no water is pumped out. Can someone advise where I can access the pump to check or what else the problem might be?
If you can see the impeller via inspection cover, there is no need to access it surely.
I would look for a blockage in the drain system, from drain hose to appliance. Take left hand panel off and you will gain access there. Un plug appliance first :plug:
Thanks Greg,
I’ve removed the panel from the LHS and removed the drain pipe from the appliance and blew through it to verify there was no blockage. So I can only assume the blockage is very local to the pump itself and that looks like a nightmare to get at.
