BOSCH SGS5312GB/12
  • #17640
    hellraiser
    Help….My Bosch dishwasher was working fine this morning and then suddenly died. All lights went out, I tried the power button again and nothing. I have checked the fuse in the plug and this is OK. Any suggestions would be appreciated.
    #175590
    Re: BOSCH SGS5312GB/12
    Mains supressors have a habit of failing on these, and the computer board develops dry joints over time.
    Power off if investigating or click the link below for a UKW rngineer if that sounds a bit daunting.
    hellraiser
    Quite happy to investigate the cause, can you supply me with any guide on what to do?
    #175592
    gegsy
    Remove lid,then remove r/h panel.
    As you look at the removed side area of dishwasher, the suppressor is at the r/h side, whitish in colour. An inspection of supressor unit will usually show any damage ie cracked/blackened.
    The supressor will detach if you get flat bladed driver under it.
    Appliance will still work without the supressor FYI.
    Power off before doing anny work on appliance :plug:
    hellraiser
    Dishwsher still not working, but, now i have lights.
    the salt and rinse aid lights are both on, the light below the program choice is on, the program display is on and what looks like a full stop in the display has appeared. Also is you choose a program the display seems to follow the program but the machine is not working.
    #175594
    hellraiser wrote:the program display is on and what looks like a full stop in the display has appeared.
    Classic symptoms of a faulty Control Module (Part No 264877 – cost around £105) 🙁
    You did first check that Suppressor like my colleagues suggested, didn’t you ❓
