Bosch SGS5312GB/12
  • #82736
    Dosser
    Hi there,
    I have a problem that the dishwasher keeps going off. I traced the fault to the on/off switch on one of the set of 3 contacts are not making. If I hold the switch in manually it works. Can I buy a new switch, although it looks complicated to change as linked to door release assembly. I could disconnect the faulty switch wires ( white wires) and join them together to bypass the switch. But this would mean switching off at the plug each time. Any advice? Many thanks. Dosser
    #420694
    Dosser
    Bosch dishwasher SGS5312GB/12
    Hi there. I see that ukwhitegoods sell the part I am after, the on off power switch which is connected to the door release assembly. How difficult is this to fit. Many thanks. Dosser
    #420695
    lee8
    Re: Bosch SGS5312GB/12
    Try cleaning around the square plastic button with an old tooth brush, sometimes they get crud which prevents it pushing back enough. If not change the switch, it’s not difficult.
    #420696
    Bear in mind, on some of these switches one set of contacts is a momentary switch so does not appear to be simply open or closed. It only makes as the switch is pressed then opens when the pressure is released. This switch is usually quite reliable. Do not join any wires or you may do serious damage.
    #420697
    Re: Bosch dishwasher SGS5312GB/12
    Merged threads, best to keep it all in one place. 😉
    #420698
    Dosser
    many thanks for all your help
    I now don’t think the on/off switch is faulty as when all the lights go out and the machine stops, if you tap the front you can hear the relay click on and everything is working again until several minutes later.i cant see any dry joints except the one I soldered a few years back on the heater feed
    any help, thanks . Dosser
