Bosch SGS5312GB/12 FD 7910 730553
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGS5312GB/12 FD 7910 730553
  • #20253
    timdowning
    This dishwasher faulted full of water…..
    Press on/off switch. Lights come on and you can select desired programme.
    Nothing happens, apart from on one occasion it filled with a small amount of water and then stopped.
    When I lift the red rod (which activates normally when base has flooded)
    The pump will run.
    When I RESET the programme nothing happens other than the display goes back to zero. (No pump activation).
    Am I right in thinking this is a board fault?
    Thanks in advance.
    #186371
    superfix
    Re: Bosch SGS5312GB/12 FD 7910 730553
    Certainly sounds like it
