Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS5312GB/12 not filling
- This topic has 9 replies, 4 voices, and was last updated 17 years, 7 months ago by
ratrsed.
August 26, 2008 at 9:05 pm #39007
ratrsed
ParticipantHello
I have a Bosch SGS5312GB/12 dishwasher that does not seem to be filling properly. Basically, when I switch it on, water comes out of holes in the rotor arms (if I open the door quickly I can see this before it stops). However, it also seems to be constantly draining the water back out again. Basically it carries on like this forever. It sounds like the drain pump is continually sucking the water back out.
There is also a red dot in the bottom right corner of the led display. Not sure whether this indicates some sort of error code??
Any help much appreciated.
Cheers
MarkAugust 26, 2008 at 11:44 pm #260914Penguin45
ParticipantRe: Bosch SGS5312GB/12 not filling
Base flooded (remove side panel to check) or pcb ‘s thrown a wobbly.
August 27, 2008 at 10:16 am #260915ratrsed
Thanks for the reply.
I shall have a look this evening. Do I need to remove the entire side panel or just the bottom bit? Also does it matter which side?
If it is flooded, is it just a case of emptying it out and hoping it works ok afterwards?
Cheers
MarkAugust 27, 2008 at 8:17 pm #260916ratrsed
OK – I got both side panels off and there is no water in the base.
Basically it looks like the water is coming into the plastic tank on the left-hand side and then is being immediately pumped back out. A small amount actually makes it to inside the dishwasher. The drain pump keeps going even if I reset the program by holding down the ‘Intensive’ and ‘Eco’ buttons simultaneously.
Is there anything else it could be other than the main pcb (which sounds expensive to replace) such as a sensor/switch that detects when all the water is gone and thus stops the drain pump?
August 27, 2008 at 8:22 pm #260917admin
KeymasterRe: Bosch SGS5312GB/12 not filling
how old is the dishwasher, built in or free standing
tonyAugust 27, 2008 at 8:31 pm #260918ratrsed
Hello Tony
It’s quite old – about 7 or 8 years old I would guess, although it had very little use for about 4 or 5 of these. It is a free standing model.
August 27, 2008 at 9:00 pm #260919admin
it sounds like the pcb is faulty then if you do remov e the board and inspect it you will sometimes see a burnt out spot which you can solder but thats normaly a heater problem ive had that fault myself a couple of times and i had to change the pcb
tony
unplug first if your not sure try the repairs@ section for an engineerAugust 27, 2008 at 9:54 pm #260920ratrsed
Yes I had the heater problem a couple of years ago with this dishwasher and solved it by soldering a small length of wire between the burnt out sections.
I’ll have another look at the pcb to see if there is anything obvious. I just wondered whether there was some sort of sensor that controls the draining operation that may be faulty??
August 27, 2008 at 10:18 pm #260921gegsy
A red dot in the display means the module is goosed Im afraid.
Module p/no 264877 available from spares@ukwhitegoods.co.ukHTH
August 28, 2008 at 11:36 am #260922ratrsed
Oh dear!
I assume these pcbs are not easy (impossible??) to diagnose and fix?? Apart from the heater problem that is, which is fairly easy to spot on it.
Thanks all for your help!
Mark
