i was recently given a Bosch Dishwasher, the first three uses took approx 90 mins and then it began to take nearly three hours. I thought either the thermostat or the heating element was perhaps at fault, however
i was lucky enough to stumble upon your site yesterday and read some of the topics and discovered that the PCB can be a problem.
i followed the advice in your posts to other members with a similar problem and could find no signs that the PCB had shorted anywhere. i put the module back together and put the machine through its cycle and the problem appears to be cured albeit in the short term, maybe vibration worked a connector loose when it has been moved who knows?
However to get to the point, i wanted to thank the moderators for their help through this forum. the advice that was given to other users worked for me and avoided perhaps replacing unnecessary parts. clear concise information.
Well done and keep up the great work.
i will not hesitate to recommend you or use you again
Many Many Thanks.
