Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS5312GB/12 Will not wash
- This topic has 7 replies, 5 voices, and was last updated 21 years, 4 months ago by
Angelvenom.
November 23, 2004 at 1:54 am #6886
Angelvenom
ParticipantThis is my first post. Hope i’m in the right place.
As I mentioned, our dishwasher will not get past the first part of the wash cycle on any program. It will just run for hours. We have had this washer for over 5 years and it has never had any problems before. I have tried resetting using the 2 & 4 buttons but no change. I have looked at the spinning arms inside the dishwasher and they appear to be clear. I don’t think there is much water getting into the system, can these dishwashers get blocked on the water intake? I’m not an expert but can take things to bits (and reassemble) so any advice would be appreciated.Many thanks in advance,
Simon.
November 23, 2004 at 5:52 am #120120admin
KeymasterRe: Bosch SGS5312GB/12 Will not wash
Morning,
Sounds as though the heater relay has a dry/burning joint on it. It is situated to the right hand side of fascia panel and is not a DIY job to rectify.
Look in the directories and pop your post code in for an agent close to you.
Kevin
November 23, 2004 at 3:57 pm #120121Angelvenom
ParticipantRe: Bosch SGS5312GB/12 Will not wash
Hi Kevin,
Thanks for the quick response.
Have had a local guy come and have a look, says it’s the heater has gone and will cost £51 for a new one. Since your suggestions was of a similar vien I will trust that this will fix the problem.Many thanks for your help,
Simon.
November 23, 2004 at 4:29 pm #120122Martin
Angelvenom wrote:will cost £51 for a new one.
Simon,
Indeed those heater are’nt cheap. I wonder what would be the labour charge to fit, as that isn’t an easy job?
Incidentally, I haven’t had an element go so far on that model. As Kevin suggested in most cases it is the Control Module that burns out. Can be even cheaper to fix?
Can I ask, when you ‘reset’ the programme, does it indicate ‘Zero’ on the LED, pump for 60 seconds then stop I wonder?
November 23, 2004 at 4:35 pm #120123Angelvenom
Hi Martin,
Yes, it does exactly as you suggest. Is this significant? (I pressume it is or you wouldn’t ask). What does this mean please.Reagrds,
Simon.
November 23, 2004 at 5:19 pm #120124Martin
Angelvenom wrote:What does this mean please.
Thought so, I will send you a personal message in reply (pm) to this 😉
P.S I reckon it will complete a ‘Quick Wash’ without incident also 8)
March 6, 2005 at 11:05 am #120125Rog
Hi, I have exactly the same problem with my Bosch SGS5312GB/12. It performs the wash cycle but never ends, it never rinses. A reset will howver stop the cycle and drain the machine.
Is it the controller that is at fault?
Any info wlecome.
Rog
March 6, 2005 at 12:02 pm #120126Penguin45
ParticipantRog,
As described in other posts in this forum, the fault will almost certainly be a dry joint on the computer board. You can double check this by setting the machine to the quickwash programme – it will almost certainly complete, as this programme runs against time and does not “hold for heat” as the others do.Do nothing internally without pulling the plug first.
Penguin45. -
