Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch SGS5318GB/12 Dishwasher
- This topic has 10 replies, 4 voices, and was last updated 17 years, 1 month ago by
robbra.
March 5, 2009 at 4:27 pm #43991
robbra
ParticipantWHat is it with Bosch. Overun with dishwashers 🙂
This one shows 0 on display. Then the bar for wash, starts to fill then either does nothing when full or drains and fills. I have cleared out the transfer hose and checked everthing else I can think of…..HELP!!!
bet Aqua has an answer
RobMarch 5, 2009 at 5:03 pm #279327Martin
ParticipantRe: Bosch SGS5318GB/12 Dishwasher
robbra wrote:bet Aqua has an answer
Not sure what or who Aqua is but “drains & fills” is usually a sticking red float chamber. If you press to “reset” does it do just that? If not I’d take a look at the module also. 😉
March 5, 2009 at 5:10 pm #279328robbra
Aqualectric Martin,
Had red float chamber apart and cleaned it thoroughly. Would I be looking for anything specific on the board?March 5, 2009 at 5:29 pm #279329Martin
robbra wrote:Would I be looking for anything specific on the board?
No need to look at the board in this case if indeed it ‘resets’ as it should? Hence my asking. 😉
Bit worried though about : –
robbra wrote:starts to fill then either does nothing when full
Does nothing when full? Is the main motor OK?….
March 5, 2009 at 7:22 pm #279330robbra
Yes motor checks out fine. If the door is opened after filling and shut then it goes into drain mode. It seems all over the place, sometimes fill/empty at same time, sometimes fill and sit doing nothing , other times straight to drain just by switching it on.
They were discussing a Miele when I was there so may not need a cure after all.
RobMarch 6, 2009 at 2:17 am #279331aqualectric
When you say you cleaned the red float; did you remove the metering chamber as a unit and split it down? (The red float is part of this unit). Strange faults can happen on these machines caused by scaling of the black plastic restrictor in the metering chamber. That is the part that the pressure switch (banjo shaped) with the microswitch and lever (blue lever, higher of the 2 microswitches) fits down into. It is clearly visible through the side of the chamber. If it gets scaled, it will back up the water and in turn lift the red float and start the drain pump.
Remove the complete metering chamber and lift out the pressure switch assembly. Then prise off the top rim of the chamber. To remove the restrictor, turn the chamber upside down and tap it smartly on a flat surface. The restrictor will then be accessible with pliers. Remove and clean then refit. When the machine is filling, the restrictor should not impede the water flow and cause it to back up and lift the red safety float. I have also had the airbox nozzle that fits into the top of the chamber block with scale. Look for that too.
If that doesn’t sort it, then PCB.Steve.
March 6, 2009 at 8:08 am #279332robbra
Thanks Steve,
I cleaned the whole lot. Right from the off the red float never lifted, the m/c just started draining either immediately or after some filling.
I think it must be the pcb.
Rob 😥March 6, 2009 at 8:42 am #279333Martin
I still don’t know if the programme resets though? 🙁
March 6, 2009 at 3:21 pm #279334robbra
Sorry Martin,
it was hit and miss. sometimes it would reset to 0 or start to fill or drain for ever.
RobMarch 6, 2009 at 4:49 pm #279335PINKY
Sound like the main Pcb if the reset is hit and miss
March 7, 2009 at 11:20 am #279336robbra
Think you’re right pinky and a t the price of £117+vat iot’s a non starter.
Rob 😥 -
