Bosch SGS5342GB/17 HYDRO SENSOR
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS5342GB/17 HYDRO SENSOR
  • #35567
    ath007
    The dishwasher started to make some funny sounds but now has ceased to do anything. The counter works on the front panel but there is no other life. New fill valve fitted but to no avail, fuse in plug checked etc.
    What is my next move and how do i get into it?!
    regards
    Arthur
    #247160
    kelland
    Re: Bosch SGS5342GB/17 HYDRO SENSOR
    unplug, remove front panel and fascia and test door switch
    #247161
    gegsy
    Maybe worth a look in the drain pump area as the pump maybe jammed.
    Access as per manual, remove filters and locate housing cover held in by a torx 20 screw. Remove screw and cover and inspect recess thoroughly.
