Bosch SGS53A02GB
  • #59675
    JoH
    Hello
    I have inherited a Bosch SGS53A02GB dishwasher with my new house and the programmes are taking 3 hours or more to complete, even when the display says a shorter time. Have cleaned fllters etc This I don’t think can be right. Any advice please?
    Many thanks
    Joanna
    #339206
    CJAPeterborough
    Re: Bosch SGS53A02GB
    If you open the door whilst running you can easily tell if there is plenty
    of water being sprayed around?
    If not then you probably have a reduced flow due to pressure chamber and lower transfer pipe to the sump being blocked.
    Is the machine heating up?
    If not then this will be another reason why the programs are running longer.
    To check this you need to know how to use a multimeter and check the resistance of the heating element.
    Plenty of threads on this -use the search function and Bosch not heating…
