Bosch SGS53A02GB/42
Viewing 15 posts - 1 through 15 (of 19 total)
  • #32802
    rocker
    This dishwasher is overfilling have changed water level mirco..even when this is unpluged it keeps filling !! can anyone help please.
    #236437
    pup
    Re: Bosch SGS53A02GB/42
    sounds like valves
    #236438
    clivejameson
    Yep…if the plug is out the valve should be shut…basic stuff really
    #236439
    rocker
    sorry I meant when the side tank.water level mirco is unpluged
    #236440
    clivejameson
    My apologies rocker i misread your post.
    If the diaphragm is activating the switch ok and it still overfills then i would think it has to be the module?
    One of the Bosch boys will be along shortly no doubt…..
    #236441
    clivejameson
    ….or a lazy valve. Easy way to check a lazy valve is to pull the plug during a fill…it should shut off pretty smartish 😉
    #236442
    whitevanman
    check the flow jug between inlet valve and metering tank, sure one of the super mods has posted info on this prob somwhere, could also be pcb as sugested
    #236443
    clivejameson
    This is the older type with the side chamber/flood switches IIRC?
    #236444
    gegsy
    Supermods 😆
    gegsy
    Yes Clive is correct no impellor jug.
    IIRC this is a timed fill from the module so if valve is eliminated from being faulty then module would be my diagonosis 😕
    whitevanman
    AHHH 166880 ??? 😳
    #236447
    clivejameson
    I’m pretty sure this one fills to level, wash pumps cuts in which drops the level, then refills to level again while washing?
    Always ready to be corrected by a mod like that of course! 😆
    #236448
    gegsy
    Yerr Clive it does do that but Ive had a fill triac once that had gone west that kept appliance filling 😕 😀
    When the filling valve has been opened, the water flows towards the integrated inlet via the free flow channel and into the water softening system and as soft water into the heat exchanger. When the regeneration chamber has filled up, the water flows into the restricting funnel of the level sensor via the overflow channel. The pressure build-up in the pressure chamber causes the level switch to open the heat exchanger drainage valve. The electronics measure the time between the opening command of the filling valve and the closing of the level switch . The additional filling time of the filling valve is calculated from this time.
    The circulation pump is switched on time-delayed, the drainage valve remains open until the heat exchanger has emptied completely.
    The water volume of completed rinse cycles is recorded by the electronics counter which determines when the water softener requires regeneration.
    Before each regeneration step the electronics check whether the capacity of the water softener is adequate for a complete “Normal Programme Sequence”. If not, regeneration starts.
    The water softening system is regenerated and rinsed through during the wash cycle. The regeneration valve on the water softening system is opened for this purpose. The stored volume of water flows into the salt dispenser via the valve, absorbs salt and flows as saline solution through the water softening system into the heat exchanger. Rinsing takes place in three stages, each with one calculated volume of water.
    gegsy
    You chaps have email 😉 Wait till P45 sees that pic 😆
    rocker
    thank for all your help gents..John
