Bosch SGS53A0GB/27
  • #35862
    S1MON
    Bosch SGS53A0GB/27
    This machine had the main modue replaced as the heater relay had totally blown the board beyound the usual repair job. Came to replace the module but the board I have got will not selector intensive wash. You can select the other programs but the intensive light will stay lit.
    Refitted several times but to no avail. It with no calibration instructions like some ive seen before
    #248435
    S1MON
    Is 482935 the correct module?
    #248436
    Beever
    Re: Bosch SGS53A0GB/27
    The ENR Number is not correct!
    If the ENR is SGS53A02GB/27 Then yes 482935 is the correct module.
    Regards
    Ian B
    #248437
    gegsy
    Beever wrote:………….Then yes 482935 is the correct module.
    Which has now been replaced by 489607 £58.12 +VAT
    Also you will need to code the module to your particular model 😉
    You have mail 😀
    S1MON
    cheers im going back friday
    #248439
    S1MON
    cheers lads reconfigered the bpard as it was set to the wrong coding
