Bosch SGS53A12GB/01 Not emptying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS53A12GB/01 Not emptying
  • #50328
    woodlands
    Woke up to a flooded kitchen this morning. Dishwasher not emptied or continued filling.
    Can’t see any obvious blockages, filter clean etc. Any ideas???? Appreciate it is a few years old
    #304422
    chalky
    Re: Bosch SGS53A12GB/01 Not emptying
    does it empty if you reset it?
    #304423
    woodlands
    Put it o a hot cycle and it seems to be going through the motions at present. It appears to be pumping but doesn’t seem to be heating up at all. Wondering if the “hot bit” is knacked and it got slightly clogged due to cold washing only???
    #304424
    woodlands
    Now gone back into flood mode and just cold!!
    #304425
    chalky
    humm sounds like it could be a fault with the timer there prone to heating faults but that would not make it leak though 😕
    has it ever leaked before?
    #304426
    woodlands
    No problems with it at all, but like I said it’s getting on a bit.
    #304427
    chalky
    if its not heating it could have been washing for a very long time waiting to heat the water up this may make it leak through a perished seal, there may also be a problem with the fill matrix as these tend to get clogged up.
    i think you probably need to call a engineer out it shouldent be to expensive tho
    HTH
