Bosch SGS53C02/GB15
  • #22350
    clivejameson
    One for the Bosch boys this one…this machine went faulty along with the customers’ computer when there was a nearby lightning strike so pcb thought I!
    However replacing the pcb hasn’t cured it….the machine puts the drain pump on correctly, fills for a minute or so then puts the drain pump on again. Thereafter it just fills for a few seconds then drains out again repeatedly.
    There’s no water in the base and the fill system is just a basic flow meter type which appears to be functioning correctly!
    Any ideas?
    #194595
    bubs
    Re: Bosch SGS53C02/GB15
    Does sound like a blocked sump hose backing up as it fills activating the pump.
    Cheers Graeme
    #194596
    bubs
    Sorry Clive 😳
    I’m thinking of the older model.
    Graeme
    #194597
    superfix
    Do you mean the circular “impellor jug” in line with valve and side chamber?.
    If so I would be almost 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain that it aint functioning correctly 🙂 .
    #194598
    clivejameson
    Yes it is boro….cheers for the help.
    #194599
    superfix
    No problem 😉
