Bosch SGS53C02GB/08 Fault
  • #33546
    CDS
    Hi i have been out to a Bosch SGS53C02GB/08 dishwasher.
    It fills and then empties straight away, and won’t do anything else.
    I have replaced the module and it is exactly the same.
    There is no water in the base of the machine.
    Does anyone have any ideas?
    Thanks Graham
    #239127
    Geoff1312
    Re: Bosch SGS53C02GB/08 Fault
    Hi Graham
    Not totally conversant with this machine, but have had a similar problem with some Bosch dishwashers where the transfer pipe that goes across the front of the machine from water inlet tank on l/h side to machine sump is blocked. And float switch detects an overfill situation and brings the pump on.
    Good luck
    Geoff
    #239128
    superfix
    If it cycles fill/empty constantly more than likely gonna be the flow meter (impellor jug) part no. 424099 about £11 if memory serves 😉
    #239129
    Turbo
    It was indeed the Impellor Jug, CDS kindly put this post up for me as my PC has been down.
    A Big Thanks
    Turbo
