Bosch SGS55C02GB/01
Does not pump out water although the pump works ok and there is no blockage and the little one way flappy bit does not get stuck. Its as if there is some sort of air lock.
Can anyone help with this unusual fault.
Regards Mark
Have you checked the little valve on the airbreak/sidechamber at the left hand side, Usualy gets all gunged up and they won’t empty.
Regards
Steve 🙂
nationalhomecare wrote:Have you checked the little valve on the airbreak/sidechamber at the left hand side, Usualy gets all gunged up and they won’t empty.
Regards
Steve 🙂
