Can you advise please the correct and safe way to open the back/side of my Bosch SGS56E02 casing so that I can replace the plastic drain hose?
Many thanks in advance
CJ
We’re not allowed to give a ‘remove screw A and B’ type description (see forum rules) for reasons of safety…you may be perfectly capable of doing the job safely but others will probably read the post too.
That said, you do need to remove the lid which has two locking barbs at the rear, and the left-hand side panel which has two screws then all will be revealed 😉
