BOSCH SGS56E02GB/47 DISHWASHER
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH SGS56E02GB/47 DISHWASHER
  • #11472
    DAR01
    Set up on Pre Rinse prog, pump starts runs for about 10 seconds then, Wash, Salt,RinseAidand pre rinse lights start flashing.
    Is this indicating a fault on the machine or is there a problem with the control module.
    Mike
    #145474
    rocker
    Re: BOSCH SGS56E02GB/47 DISHWASHER
    DAR01
    I suggest you check water inlet valve first, that you have 240v in and also the valve is not faulty before buying pcb. also if you have a side tank checked this out it isnt blocked and mirco switch is operating.
    john
    #145475
    DAR01 wrote:Is this indicating a fault on the machine or is there a problem with the control module.
    Very unlikely the Module is at fault as long as when you ‘reset it’ it pumps for 60 secs then turns off, thus indicating it is OK.
    I would, as Rocker suggests, check the obvious especially the water level system, flooded base etc etc 😉
