The dispenser for our Bosch SGS6302GB/07 dishwasher has stopped automatically opening during a cycle but can still be operated (openedclosed) manually.
The rest of the machine operates normally and we have power etc.
Any advise on what I need to do to fix this?
Could it me an electronics control board that needs replacing?
yes, the spring is fine
I did removes the door panel erlier on the week to replace one of the buttons and wonder if when disconnecting hte wiring I may have shorted soemthign.
I thought the unit was turned off but then realised that it wasn’t.
If it tries to take your finger off, that’s good. It’s possible that the actuator has failed – it is a spare part; but as you say you have had the door panel off, I’d check that the plug to the module is located properly before going any further.
