Bosch sgs6302GB/07 no lights
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch sgs6302GB/07 no lights
  • #21612
    unwashed
    I have a bosch dishwasher which on the last couple of occaisons hasn’t been emptying fully at the end of cycle.
    Now we have tried to use it but we are getting no lights on the front panel at all. I have checked the fuse and also that the water supply is on.
    I have also taken the cover off by the rubber impeller and this seems to freely spin.
    Any ideas?
    Ps for the past month or so the timer seems to go to 98 minutes for whatever cycle is programmed is this a related problem.
    #191877
    gegsy
    Re: Bosch sgs6302GB/07 no lights
    What I would do is check another appliance in the socket the dishwasher is plugged into and see if it works so we can eliminate that.
    If the other appliance is fine I would seek proffessional help, please use the link below on my sig.
    unwashed
    Tried another appliance in the socket and that works ok.
    #191879
    unwashed
    I removed all water from machine and then managed to get dishwasher to work by resetting using on/off button and holding in the program buttons.
    The countdown display then went to 97 mins and the machine started working but it only got to approx 87 mins and then completely stopped again with the base full of water.
    Any further ideas as to what could be the problem?
    #191880
    gegsy
    I think this fault requirs an engineer visit to be fair as the fault sounds quite in depth.
    Please feel free to use the link below.
