Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS6312 stuck
- This topic has 4 replies, 3 voices, and was last updated 19 years, 7 months ago by
pms.
August 23, 2006 at 2:01 pm #20221
pms
ParticipantHi
Last time I was on here and had a fault on this machine you helped me fix it with little difficulty so I’m living in hope this time.
The current problem is that I put the machine on last night and went to bed only to find it still on the rinse cycle this morning. I have checked the hose connection and that seems ok and made sure the pump isn’t blocked. I have
also started the machine severaltimes but it does not seem to fill. When I opened the door this morning the soap tablet was in the machine but undissolved.
The only other perhaps relevant thing is that the display is showing a red dot in the bottom right corner.
I would be most grateful for any advice.Peter
August 23, 2006 at 3:34 pm #186265Martin
ParticipantRe: Bosch SGS6312 stuck
The base is flooded I would think? UNPLUG THE MACHINE FIRST :zap: and tip the whole machine on its back enough (about 45 degrees) to allow the water to leak out. (Backwards remember, not sideways!!)
If water does leak onto the floor, the problem is solved for the short term at least. You should find it now works OK?
If not then click the link below for local help. 😉
August 23, 2006 at 4:06 pm #186266pms
Thanks very much for that Martin. I had tried that about half an hour ago after finding a similar problem on the forum but I also tipped the machine sideways. A pile of water did come out and when the machine was switched on it sounded more normal. However it does seem to be filling but very slowly and I think the pump is operating continuously and as before the arms aren’t working.
Have I messed it up by tipping sideways and
Is it likely to be a big repairThanks once again
PeterAugust 23, 2006 at 10:08 pm #186267gegsy
pms wrote:The only other perhaps relevant thing is that the display is showing a red dot in the bottom right corner.
Module is faulty then.
The module you require is p/no 264877. Please use the link for spares on my signature below or engineer link if required.Greg
August 24, 2006 at 8:31 am #186268pms
Thanks very much Greg. I’ll check on the spare and see if I am able to fit it myself.
Peter
