Bosch SGS6312GB/07
  • #12019
    Dave_Conway
    This is an odd one…..
    The Dishwasher starts up, drain pump runs for a while as you’d expect then the circulation motor kicks in on it’s own (no fill) and runs continuously.
    Abort the programme, put it on a test cycle and it runs perfectly, fills, circulates, heats and drains. Normal programmes just won’t work at all 😕
    So, we replaced the main control PCB and all was well for a month then the same happened again, nothing else found so another PCB was fitted and it worked for 2 washes and now is back to square one :con:
    Am I missing something or just bad luck with three PCB’s doing the same do you think ?
    Dave :haier:
    #147545
    bobokines
    Re: Bosch SGS6312GB/07
    Really strange. I had a similar one yesterday and was about to post a question. Mine is a model SGS66A02GB/13.
    At turn on the every electrical component runs at the same time. Pump, circ motor, fill valve, transfer valve. There is no display at all and the reset does not work. Is it something with these modules?
    I am guessing at the module but I’m a bit stumped.
    Bob
    #147546
    If the insulation is down on the main circulating pump (even slightly – 100megs or so) it can cause the board to do a wobbly 😕
    #147547
    superfix
    Agree with Martin on this one probably low insulation on something.If not did have problems with dispenser actuators on some models, insulation problem on these don’t always show up on megger.
    HTH.
    #147548
    Dave_Conway
    Thanks chaps 😀
    I’ll get the engineer to check these over and report back.
    #147549
    andy2
    Martin wrote:If the insulation is down on the main circulating pump (even slightly – 100megs or so) it can cause the board to do a wobbly 😕
    Is it a permenant wobbly or will the module function OK after the pump is sorted?
    Just interested. 🙂
