Bosch SGS6312GB/13 – Dispenser not opening
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS6312GB/13 – Dispenser not opening
  • #39658
    headache5678
    Having replaced the Acctuator (the wax / motor part) the soap dispenser door will still not open automatically. Worst case scenario seems to be a new Control Module at £100 – but I replaced that last year.
    Would it be advisable to run a low current 240v through to the blue wires of the Acctuator and, if it pops open, that would presumably confirm that the Control Module was faulty or there was a poor blue wire-> control module connection ?
    #263097
    Re: Bosch SGS6312GB/13 – Dispenser not opening
    Take it from me that a brand new actuator is guaranteed to work. The fact that it doesn’t when installed correctly into position and connected up. Means only one thing…you’ve guessed it already….yes…the module is at fault. 😥
    #263098
    headache5678
    Martin,
    Thank you.
    Upon opening / separating the door again I found that two pairs of wires, one yellow pair and one blue pair, had come adrift (from the Control Module?).
    Both the yellow pair and the blue pair start from the Actuator and I guess both connect to the Control Module but where ?
    Can you sell / supply a wiring diagram pelase or give me a clue maybe?
    Thank you
    Kevin
    #263099
    The plug-in connectors only fit into the socket to which their pins and cut-outs allow them to be relocated. (i.e the yellow connector block won’t fit into the blue and vice versa) 😉
    #263100
    headache5678
    Re: Bosch SGS6312GB/13 – Wiring Diagram
    Thank you, all wires now connected and as fault remains I will replace the Control Module next – which I only replaced last year.
    For future interest I know that wiring diagrams etc are instantly available, but not freely to the public, on the website :
    https://www.tradeplace.com
    Is there any way that I can get such diagram please ?
    #263101
    Yes, become a bona fide trader with an account with each manufacturer you require details of.
