Bosch SGS6342GB/07 Dishwasher Blown board Tracks
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGS6342GB/07 Dishwasher Blown board Tracks
  • #12245
    Simon46
    Have been to look at Non RCD protected house with blown tracks and components on Board. The third track with red white wire to switch has popped along with a couple of Resistor shaped components. The usual suspect Relay track has also blown But customer did not report cold wash/ infinite wash. Is this a symptom of the common heater relay track?
    Have not seen this before.
    S.
    #148655
    Re: Bosch SGS6342GB/07 Dishwasher Blown board Tracks
    You’ve got a short somewhere Simon – the heaters do blow occasionally, but you’re going to have to check everything. These ones don’t seem to do the broken wire in door thing, so it’s got to be a component failure. Motor and heater are the only things that draw any real current so start there.
    Simon46
    Thanks Chris. Will check heater motor etc. If it has run for hours i suspect fried motor.
    S.
    #148657
    Simon46
    Fitted a test board i had to check operation. Does the heater come on, on the first 70 degree saucepan wash which i would have thought would be a cold prewash. Test board has had heater relay resoldered.
    No shorts/LI/leaks. Sat watching quickwash o.k. Lots of spilt tea on top though. 😕
    Simon
