Bosch SGS65L12 won’t run cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS65L12 won’t run cycle
  • #43223
    markymark74
    Have searched for this without success so decide to post. I have the above Bosch d/w (3 year old LogiXX) which died towards end of cycle. There was no obvious signs of power and bottom tray was full of murky water.
    I traced through power from plug to switch on front and eventually to PCB after dismantling where I found two blown tracks.
    I repaired the tracks with spag wires and it now powers up and everything appeared OK until I tried to run a cycle.
    On starting a cycle it drains and fills OK but then stops with bottom tray full of water.
    I now suspect heater failure caused PCB damage but has anyone seen this before.
    Any help very much appreciated
    Mark
    #276475
    markymark74
    Re: Bosch SGS65L12 won’t run cycle
    An update is that on all cycles the base tray fills with water but then nothing. After a reset it empties and re-fills. The electronic timer counts down but nothing happens mechanically. Is there anything I can check before calling an engineer?
    Thanks for any help you can provide
    Mark
