bosch sgs65l22gb/01
  • #40786
    robbo1973
    been here today and uplifted into workshop I dont generally do dishwashers but this a love job.the machine as soon as you switch it on even with the door open the drain pump runs continuosly and thats it.no fault codes
    any advice appreciated.I suspect module as machine starts with door open and the lock aint engaged.
    cheers chris
    #267539
    aogrady
    Re: bosch sgs65l22gb/01
    Hi!
    Pump running with door open is due to the anti flood float in the bottom being triggered. You have a leak from somewhere, could be main motor seal, the rubber do-nut from sump to motor, outlet hose or pressure system possibly.
    Cheers!
    Alistair
    #267540
    robbo1973
    I thought it could be in fllod mode so i tipped it up and no water came out.
    #267541
    pup
    robinsonrobbo wrote:I thought it could be in fllod mode so i tipped it up and no water came out.
    flood s/w stuck?
    #267542
    robbo1973
    should machine still function with door open?
    #267543
    robinsonrobbo wrote:should machine still function with door open?
    Anti flood device Rob, only the drain pump operates when door opened and still powered up. 😉
    #267544
    superfix
    Good old gunge in the the pressure chamber can keep the red float in the “made” position and give the same symptom as flooded base.
    #267545
    smartin
    have had quit a few where mice have taken a likeing to the styrene float causing bar to lift giving flood fault hope this helps
    #267546
    robbo1973
    thanks very much for all the replies will update when i look at it in the workshop.cheers
    #267547
    smartin
    dont forget the cheddar 😆
    #267548
    robbo1973
    the float was stuck in the made position dont do much on dishwashers what threw me was running with the door open thanks all for replies.
