Bosch SGS66A02 locked up with error code 1
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS66A02 locked up with error code 1
  • #85901
    andy_c
    Just come back from holiday and used dishwasher for the first time. It appeared to start OK. After a few tens of minutes I came back into the kitchen to hear it humming loudly and what I presume to be error code 1 on the display (left most digit lit – none of the programme LEDs lit).
    The dishwasher was full of dirty water and I think some material which was trapped in the dishwasher before we left from the look of it. I’ve emptied this all and taken the machine apart and ensured all accessible hoses, including those connected to the fill matrix are clear. I’ve also ensured that the pump is running and not jammed. The dishwasher has now emptied itself of the final dregs of water, but I can’t persuade it to do anything but show a 1 as an error code and hum at me.
    Any clues where I should be looking next please.
    Andy
    #429775
    Re: Bosch SGS66A02 locked up with error code 1
    Does it still operate even with the door open?
    #429776
    andy_c
    No – door open stops the machine as usual
    #429777
    Have you tried the programme reset proceedure. (ie pressing the 2 reset buttons etc)????
    #429778
    andy_c
    Yes – that’s one of the odd things – the program reset function has no effect
    #429779
    arjc wrote:Yes – that’s one of the odd things – the program reset function has no effect
    Then the bad news is that the main ‘control unit’ has died. 🙁
    Before you went on holiday did you ensure the dishwasher was switched off or was the power button still left on?
    #429780
    andy_c
    Thank you. Yes – that’s what I was worried may have happened. I presume there is no master reset function on the control board? Dishwasher was turned off on unit power switch when we went away. It all started up OK this morning, but clearly seems to have had a fit since ;-( Time for a new machine I think…
    The gemilins clearly took residence in the house while we were away. Windows 10 install also locked up at 82{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} this afternoon…
    Andy
    #429781
    Windows 10 too huh? Technology gorn mad and no mistake.
