Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS6962GB/13 No water pumper to rotor arms
- This topic has 13 replies, 2 voices, and was last updated 17 years, 9 months ago by
CityFan.
June 15, 2008 at 4:46 pm #37401
CityFan
ParticipantHi,
My Bosch SGS6962GB/13 has stopped working. When you start any cycle, the pump operates to empty residual water and the water tank fills ok and then no water is pumped to the rotor arms to clean the dishes. The Timer continues counting down. I have taken the LHS panel off to observe this. There was some water at the bottom which I have drained, then reset the machine with the same result. Can you give me any ideas as to the problem please ?
June 15, 2008 at 6:04 pm #254765Penguin45
ParticipantRe: Bosch SGS6962GB/13 No water pumper to rotor arms
Can you hear a faint humming noise after the fill sequence? If you remove the RHS panel, you will be able to observe the circulation pump. With the power off, you will able to check whether or not the pump is free to turn. If it does turn freely, most likely the start/run capacitor has failed.
June 16, 2008 at 9:09 pm #254766CityFan
ParticipantHi.
Thanks for the guidance…
Bad news, the circulation pump is not free to turn 🙁
I’m trying to turn the pump (power off) by using a screwdriver on the fins… it’s stuck fast, no movement whatsoever.There is a slight oxidation build up on the outer casing and a small amount of water under the pump housing. Is it a pump replacement job or is there something else that it could be?
Regards
June 16, 2008 at 9:19 pm #254767Penguin45
Not good….. The seal in the pump chamber will have failed and allowed water to run into the front bearing, which has now seized.
You’ll need a motor (267773) and seal kit (183638) – spares@ukwhitegoods.co.uk will be able to get these for you promptly. The real problem is fitting – the whole stainless steel cavity has to come off. As a pro, I can do it in about an hour and a half – you may need to organise a Sunday 😀 .
June 16, 2008 at 9:52 pm #254768CityFan
ParticipantThanks,
Looking at the price of other motors it may well prove unviable ?
Is there a link to an engineering exploded view of the workings of my dishwasher so I could gauge whether to attempt it ?
June 16, 2008 at 11:00 pm #254769Penguin45
http://www.bshappliancecare.com – follow the links into the eShop for diagrams.
June 28, 2008 at 12:38 pm #254770CityFan
ParticipantOK, got my spare parts (thanks), I looked through the exploded view and drained the sump… Looking at the size of the motor and the impeller seal kit it looks like I’ll need to take the base off, or am I missing a trick ?? Is it easier to work at this by tipping it on it’s side (so the side is now on top) or to tip it onto it’s roof, back ?
June 28, 2008 at 5:27 pm #254771Penguin45
Penguin45 wrote:The real problem is fitting – the whole stainless steel cavity has to come off.
All fixings in the base of the cavity, four screws retaining the cavity to the plastic chassis, door tension springs all have to come out. It’s advisable to get the fill matrix out of the way too.
Quite a job………
Good luck,
Penguin45.June 29, 2008 at 4:57 pm #254772CityFan
ParticipantHi P45,
Do I need to take the door off or will it lift off with the stailess steel cavity. Have disconnected everything I can see that retains the cavity… wiring loom, tensioners, water matrix, salt reservoir, can’t see any screw at the bottom, but there is a hole at the front of the base behind the front cover (size of a finger) with arrows left and right and an up and down arrow – what’s that for ?
June 29, 2008 at 5:08 pm #254773Penguin45
Good point – the hinges will stay attached to the base, so it’s got to go. Unclip the white inserts and the door should lift up and off.
June 29, 2008 at 11:06 pm #254774CityFan
ParticipantWhite inserts…. they’re the ones on the underside of the door hinges, about 1.5cm wide with a ridge up the middle ? Having trouble getting them out in situ… do I need to strip the door panel off ? or is it a pair of pliers and a bit of elbow grease (don’t want to bust them !!),,,,, or am I missing something ?
Ta
June 29, 2008 at 11:11 pm #254775Penguin45
Door outer panel off. The inserts just pop off sideways, honest.
July 6, 2008 at 9:24 pm #254776CityFan
ParticipantHi,
Nagging doubt re: the bolted capacitor on motor… specifically the polarity,,, there’s no indicator of polarity, so I take it the black & red wires can connect to either terminal ?
July 6, 2008 at 10:54 pm #254777Penguin45
AC circuit – doesn’t matter.
