OK, following excellent advice last time – cleaned out pressure chamber, my dishwasher is now leaking onto the floor during the wash cycle. I opened the door and it seems that the water level is too high, and the water is leaking passed the door seal.
This model has a timed fill 😕
When you first go to the appliance to fill it, is there any visible water in the tank above the filters? (Always a little below them 😉 )
If so you may have a weeping fill valve putting a small amount of water in, then the machine fills to the correct amount but obviously now it will be too much 😕
