Bosch SGS8812Gb/27 dishwasher pump
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGS8812Gb/27 dishwasher pump
  • #42218
    ray.t
    Hi I went to look at one of these today that won’t pump the water out.
    I have checked it all the way through and I think there is something stuck in the pump.
    My question is, what is the best way to get at the pump?
    Thanks Ray
    #272765
    bzz67
    Re: Bosch SGS8812Gb/27 dishwasher pump
    cup out all the water. then under the filters on the left hand side there is a plastic cover held in with a t20 torx screw, undo the screw and lift out the cover. you then have access to the pump impeller. usually a small piece of glass will get jammed in these. ( mind your fingers!!!! )
    #272766
    timdowning
    Rather than cup out the water, put a washing up bowl in the dishwasher and take off upper spray arm, set it to a cycle and hope it starts circulating, the water will then fill the bowl. Syringe out the water left in the sump.
    #272767
    ray.t
    Thanks for the replies. I thought I was going to have to get the pump off and it didn’t look like it was going to come off easily.
    Cheers Ray
    #272768
    bzz67
    even if you have to get the pump out its quite simple, gain access through front covers, remove push fit clear hose (clean it if gunged), the pump is a simple twist fit to remove.
    #272769
    funkyboogy
    phone ahead and get customer to empty out sump,
    after all it is their mess,
    if there nice they will probally have this done anyway..
    ally
