Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch sgs8812gb/35
- This topic has 5 replies, 2 voices, and was last updated 15 years, 5 months ago by
eng14.
October 16, 2010 at 12:23 pm #58025
eng14
Participanthallo this dw needs new pcb which we have,there is a mod to dowith it namely changing the plugs sicasym for g and h control.in case of equivilent control the wire at module terminal clanp 5 of appliances up to ki12 must be cut through and fitted to enclosed double terminal at wire clamp 7.in laymans terms on the sheet which way is terminals 5&7 from the right or left looking at the card straight on,any one done one please,richard. 😕
October 17, 2010 at 9:46 am #333137Martin
ParticipantRe: bosch sgs8812gb/35
What are you like eng14? Why didn’t you post this question in the other thread you raised on the subject eh? 😉
I answered you earlier question on the subject in detail and even sent you a coding sheet via email (no response from you regarding the latter):rolls:
Having got that off my chest I suggest you ignore the 2 terminal connector block modification and just configure the board the way I showed you. 💡
Perhaps at some point you can let me know how you get on, maybe? 😕
October 17, 2010 at 3:05 pm #333138eng14
martin sorry yes we did try with code u sent found some of my old ones as well.no this mc will not play ball,all progs are fine except quick wash which will not come down from 145 mins.thats why i put it back on the site,watch this space 😳
October 17, 2010 at 5:07 pm #333139Martin
eng14 wrote:all progs are fine except quick wash which will not come down from 145 mins.thats why i put it back on the site,watch this space 😳
Apology accepted by the way. Now, the problem you have with Quick Wash is simply that you have not configured it correctly. With all the info I have given you I would ask that you simply go again with the configuration (with the module out of the fascia) and reset it. Once done, quick wash should show up at around 30 mins IIRC…OK?
October 17, 2010 at 5:16 pm #333140eng14
thankyou very much martin,ill reset out of facia on 2 reset buttons and start again richard, 😀
October 18, 2010 at 4:23 pm #333141eng14
martin the machine is fine when configured out of facia,put the silly thing back in and its wrong,you were right the times are perfect out of facia,richard, 🙁
