Bosch SGV 4313 Anti-flood not filling
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGV 4313 Anti-flood not filling
  • #24696
    billwebb57
    Dishwasher will not fill automatically. I found the only way to get it to fill is to lift the anti-flood pushrod hence activating the microswitch .
    The machine will fill and then shut off when full, starting the wash cycle?
    Everything else after that works normally? seems strange that it will only FILL while tripping the anti-flood? Help!
    #202991
    Fairdeal
    Re: Bosch SGV 4313 Anti-flood not filling
    The purpose of the Anit-flood switch if activated is to drain the water out and must not take water in.
    Anit-flood is at the bottom of the dishwasher.
    I think you are talking about the diffrent microswitch with the red rod on left hand side.
    You have to check the mehansim on these to see if something is not clogged and why the water is not comming into that chamber
    Regards
    #202992
    gegsy
    Can you supply the full model number, usually etched onto inner door top as you open door.
    billwebb57
    Thanks for the reply. I guess what threw me was the fact that the ‘red rod’ is resting in a cam arrangement with a polystyrene float in the tray. It looks logically that water in the tray would raise the rod and trip the microswitch shutting off the water. But this is not the case so I will investigate into the chamber not filling now i know different. Thanks again.
