Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGV4313gb/17 – Pump wont stop
- This topic has 6 replies, 3 voices, and was last updated 19 years, 3 months ago by
Dunch.
January 2, 2007 at 1:01 pm #23744
Dunch
ParticipantPump is going all the time machine is switched on. Cannot use any programs.Have removed as much water from around pump (under the cover) no apparent blockages. Having read this group appears base may be flooded – How do I remove the baseplate – & where is it situated on the machine. Access not easy as this is an integral machine.
Thanks for any help
January 2, 2007 at 3:47 pm #199202Martin
ParticipantRe: Bosch SGV4313gb/17 – Pump wont stop
Get expert help to sort this one as it will require removing the machine to drain off the flooded base and to establish where the internal leak is that’s causing the fault? 😕
Click on link below for a local independent engineer to take a look. 😉
January 2, 2007 at 11:35 pm #199203Dunch
Thanks for the advice Martin
Have had a look at the machine & there’s nothing obvious that I can get to easily.
Will contact someone in the know to save me some grief !!
January 6, 2007 at 6:47 pm #199204Dunch
Just bit of feedback with this one – repair man took baseplate off expecting a flood of water but got nothing – not a drop!
He tested the float switch etc & problem appeared to lie with the contol panel thinking the flood switch had activated when it was actually ok.He got back to me with a quote for a new control panel – £370 😥
Am now in the market for a new machine – despite this one dying after only 6 yrs I’m still tempted to stick with Bosch – any comments ?
Cheeors
January 6, 2007 at 7:12 pm #199205Penguin45
Electronic board is p/no 264882 @ £102.34 + VAT according to http://www.bshappliancecare.com – seems to be a hefty labour charge there……
January 6, 2007 at 11:29 pm #199206Dunch
Thanks for the response Penguin45 – you have just saved us a lot of unecessary expense 😀
Maybe should have used an engineer from this site in the first place 💡
Am assuming this part will not be a DIY fix ❗
January 7, 2007 at 12:11 am #199207Penguin45
Dunch wrote:Am assuming this part will not be a DIY fix ❗
It’s a like for like swap – how brave are you? Expensive part, so you need to be sure in your mind that this is the problem. From what you’ve said, it’s a reasonable deduction; I have seen it before.
If you choose to use the repairs@ facility on the site you should be able to find a local engineer. He’ll need an hour, perhaps an hour and a half to fit and fully test. You should discuss the rate when you make the call.
Best of luck,
Penguin45. -
