Bosch SGV43A03GB/17 – stopped, but power,no panel lights
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGV43A03GB/17 – stopped, but power,no panel lights
  • #76218
    tony_heyworth
    My integrated Bosch SGV43A03GB/17 failed to finish a cycle.
    Only cup fills of water left in the base. Small amount of water in the soap compartment but it didn’t open. When the power button is on the pump whirrs and seems to fill the base of the washer – when the door is open – but no panel lights lit.
    Pulled the machine out to check drain pipe etc. Pressed reset whilst power on but no lights. Salt light started to show but dim. Switched off, waited, switched back on, pressed the 50 temp button and a cycle of some sort seems to have started with the End, Salt and RinseAid lights lit but no temp programme light showing.
    Any ideas?
    Thanks Tony
    #397694
    Re: Bosch SGV43A03GB/17 – stopped, but power,no panel lights
    Control PCB by the sound of it 🙁
    #397695
    tony_heyworth
    Thx for replying. Sounds terminal…
    The ‘cycle’ ‘finished’, it filled with warm water, but no use of the soap, now no lights at all.
    But press the power button and it wants to start again probably to repeat the same, but no lights.
    Repair or replace – sounds like replace?
    Thx Tony
