bosch sgv48m43gb/82 D/W not completing cycle.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch sgv48m43gb/82 D/W not completing cycle.
  • #82107
    nospin
    This machine completes cycles 60{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time. I fitted a new PCB a few weeks ago. It seems to run ok on quick/glass wash. Only a 22min cycle. No blockages anywhere. No leaks. Any ideas please?
    #418709
    Re: bosch sgv48m43gb/82 D/W not completing cycle.
    Computer says NO to that model number, try again.
    Did the PCB come with configuration instructions?
    #418710
    nospin
    Hi, yes. I had to configure it. Before I put pcb in, machine wouldn’t do anything.
    #418711
    nospin wrote:Hi, yes. I had to configure it. Before I put pcb in, machine wouldn’t do anything.
    Thought so, therefore I’m thinking you may need to check and double check that you configured it for the correct model? What is the correct model ENr number as the one you published doesn’t exist?
