Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGV56A03 not finishing cycle
- This topic has 5 replies, 4 voices, and was last updated 21 years ago by
SimonC.
March 12, 2005 at 10:04 pm #8442
SimonC
ParticipantHi,
Our SGV56A03 is about 2 years old and has stopped finishing its washing cycle. It seems to get through the main wash OK but then runs for hours with a 1 in the display when I open the door. I can also hear the pump running the whole time its doing this.
After scanning the other posts on the forum I’m guessing its the control module relay, but it also fails on a quick wash cycle with the same fault.
Its resets OK each time.I’m going to pull the control board out anyway for a look, but have any of you any other hints about possible faults?
Simon C
March 12, 2005 at 11:45 pm #128676Dave_Conway
ParticipantRe: Bosch SGV56A03 not finishing cycle
If the pump is running continuously, it may well be a leak and the base has flooded causing the flood protection switch to activate.
March 13, 2005 at 10:47 am #128677gegsy
Have seen this fault. I found that if the metering ribbed hose or metering unit on L/H side gets gunged up, this can send electronics into confusion.
Worth checking that hose anyway. Situated behind front plinth app 1ft in length and ‘O’ ringed either end; one to metering unit other end to sump.As Always always unplug before doing any work :plug:
If in any doubts of ability just look no further tahn repairs@
Greg 🙂
March 14, 2005 at 9:04 am #128678SimonC
Pulled the relay board over the weekend and its perfect. I resoldered all the joints anyway while I was at it. No luck…
Thanks for the other suggestions, I try them tonight.
The other thing that we have noticed is that during the first filling cycle the water inlet valve pulses 5 or 6 times right a the start. Its always done this since new, but is this normal?
Simon C
March 14, 2005 at 11:33 am #128679Dave_Conway
Sometimes high water pressure can cause this effect, if the valve is recieving pulsed power though, this is not normal.
March 14, 2005 at 2:26 pm #128680Martin
Simon C
Pay particular attention to Gegsy’s post about the hose from the meter tank to the sump….that will solve your problem 😉
