Bosch SGV56A03GB/12 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGV56A03GB/12 Dishwasher
  • #62983
    robbra
    Just pumps and fill continuously with door open or shut. No water in base,No flow meter.
    Read out of 188 mins.
    Won’t reset.
    Both m/sws ok and when flood m/sw activated valve shuts but still pumps with door open or shut.
    Looked at the piston on the rinse aid and as soon as power on door open or shut the piston moves out.
    Not sure what else to check so any ideas???
    Rob
    #352086
    mikethemechanic
    Re: Bosch SGV56A03GB/12 Dishwasher
    i know this is not what you want to hear but i can only think the module as it wont reset i suspect you have removed and examined the module??
    i would put money on it?
    the only other time ive had the fill and empty fault and its not been the impellor jug ive found the circ motor jammed or faulty but the module would still reset i guess you need to bite the bullet and fit the module
    #352087
    PINKY
    Blown Triac on the pcb without a doubt. Going to be caused by? Dispenser coil or water point motor i’d say
    pink
    #352088
    robbra
    Thanks lads.
    I hadn’t removed the module as it wouldn’t reset from the start and after my tests I suspected the module.
    8 years old so they don’t want to spend too much on it.
    I’ll price it up and tell them.
    Thanks again
