Bosch SGV57T03GB – sticks at 1
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGV57T03GB – sticks at 1
  • #55899
    Poppysdad
    Our bosch dishwasher SGV57T03GB fails to switch off, the countdown timer stops at 1, the pump continue to run although there does not appear to be any water left in the dishwasher and finally some or all of the dishes are more often than not still wet. The fault occurs with any of the programes
    I really would appreciate and help or advice that anyone could give
    Many thanks
    #325516
    CJAPeterborough
    Re: Bosch SGV57T03GB – sticks at 1
    Check out the thread below.
    sounds like your heater element…is it heating?
    http://www.ukwhitegoods.co.uk/modules.p … dishwasher
    #325517
    nomadPaul
    Its more than likely to be the appliance running with low water levels and therefore its not heating . The noise of the pump you can hear will probably be the circulation motor running with no water.
    Read through the thread CJA has posted and that should point you in the right direction .
    #325518
    Poppysdad
    to CJAPeterborough and nomad paul
    thanks for pointing me in the right direction looks like i may have a fun weekend
