bosch sgv57togb/07
  • #52139
    funkyboogy
    dishwasher doesnt take enough water in , wash motor does kick in but prog wont advance, suspect not enough water to bring heater on ??
    have checked sump hose no blockages…etc
    ally
    #310734
    nomadPaul
    It’ll prob be the pressure chamber mate. You may find it all gunged up and backing up into the pressure switch itself causing the machine to think it’s full when it isn’t.
    Best way to check is to watch it fill with the left hand side panel off. The heat exchanger should fill completely then totally empty via the pressure chamber. Watch to see if you get ‘backing up’ in the pressure chamber.
    #310735
    funkyboogy
    Re: bosch sgv57togb/07
    cheers .. can you clean them or is it best to renew
    if so do you have part no handy ..
    cheers ally
    #310736
    nomadPaul
    The part number for the pressure chamber should be 497570 – That’s if the ENr number you’ve posted is wrong and i’m presuming it is SGV57T03GB/08. I believe that they can be dismantled and cleaned out. In my position though , i tend to replace them as it’s mainly under warranty/insurance jobs.
