Bosch SGV59T03GB/10
  • #94354
    lyndy
    Customer complaining that machine isn’t getting hot enough on last rinse cycle to complete drying cycle. Thermostat has been changed. Machine is not showing a fault code. Is no longer beeping at the end of program but count is back at 0.
    #457106
    Re: Bosch SGV59T03GB/10
    Is the water flowing in and out of the metering tank, especially the heat exchanger part as that could be the problem. Never have I experienced a problem with the NTC/thermostat unit on these. Usually it’s a drain valve issue or the fill system gunged or even they use ‘Quick Wash’ and expect it to dry as well. :rolls:
