Re: Bosch SHV43A03GB – not getting past filling up
Access is very limited, you can see the circulation pump and possibly check if it is seized though.
Remove the mains plug, drag the machine out and remove the right hand (from front ) side panel.
You can then see the back of the main motor, low down, bottom left.
You may just be able to poke a thin screwdriver into the back of the motor to see if you can move the cooling vanes inside the motor.
Replacement motor is quite expensive and involves a major strip down to change.
