Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch SHV55MO3GB/56
- This topic has 8 replies, 3 voices, and was last updated 12 years, 3 months ago by
clayside.
December 30, 2013 at 7:04 pm #78789
clayside
ParticipantHave customer just phoned says does not matter which programme selected after a few minutes it stops programme and shows prewash light. Is this showing a fault code?
Regards
ClaysideJanuary 3, 2014 at 9:25 am #406899clayside
ParticipantRe: Bosch SHV55MO3GB/56
Will this model show fault codes via programme indicator lights?
January 3, 2014 at 11:48 am #406900Martin
clayside wrote:Will this model show fault codes via programme indicator lights?
Not without accessing the service programme no, not to the user anyway.
Has she tried the reset procedure?
Have you checked anything on it yet, base flooded, that sort of thing???!
January 3, 2014 at 12:22 pm #406901clayside
Hi ,Martin,
Yes she tried reset, don’t think base is flooded as she says when door opened at end of programme drain pump not running ( no noise from machine) Not had one that jumps from auto or quick wash to prewash light after aborting programme. If say a quick wash is selected machine fills and pumps then after approx 5-7 minutes programme is stopped. Machine is as usual with funny faults 50 miles from me and is a friend.January 3, 2014 at 2:36 pm #406902Martin
Hmmmm? Possible PCB burnt relay connection?
January 3, 2014 at 3:45 pm #406903clayside
Thanks Martin,
Will have to go down over weekend and look at the beast.
Regards
claysideJanuary 3, 2014 at 8:26 pm #406904nomadPaul
Does it stop after approx 15mins ? One thing to check…..and I’m pretty sure this will be the problem…..is there a screw or some other ‘obstruction’ right above the pre-rinse button as the door closes ? My guess is something is pressing down on the pre-rinse button causing that particular cycle to be selected as door shuts !!!
January 4, 2014 at 6:55 pm #406905clayside
Spot on Paul, the machine was removed from housing to get to a pluming fault behind it and the screws not been screwed up tight. When I first spoke to them not a word about machine being moved until I questioned them. Thanks, you and Martin saved me a wasted trip. Clayside
January 4, 2014 at 10:07 pm #406906nomadPaul
No probs , fella. The question has been asked a couple of times on here and it’s one of the odd faults I’ve seen that I actually remember 🙂
